Lower control arm bushing location
Discussion in 'Technical' started by 1973Ford, Sep 14, 2022.
  1. 1973Ford
    1973Ford Member
    North Scituate, RI, USA
    1973 Maverick, 76 Maverick
    Good evening,
    I installed new upper and lower control arms on the passenger side of my 76 today.
    The lower control arm bushing is pressed so that it is approximately 3/4" exposed to the rear of the vehicle, almost flush on the front.
    The original arm I removed was centered.
    I looked for new lower control arms online, and they all had the bushing offset like my new one, oddly both left AND right are the same part number. This puts the control arm forward on the passenger side and rearward on the driver's side.
    This doesn't seem right. Any input?
    Thank you.
    Jim P.
    Russell likes this.
  2. Russell
    Russell Orejano
    New Mexico, 88022
    Maverick
    Hey, Jim P....I don't have the answers you are seeking, but that seems odd...someone with more savvy will eventually help you or add to the confusion...
  3. Krazy Comet
  4. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I bought Moog and they are centered too.
  5. Acornridgeman
    Wisconsin
    It looks like it wasn't pressed in to center from the manufacturer. They do move, just center it. Having access to a hydraulic press here would be nice.
    TeeEl likes this.
  6. 1973Ford
    1973Ford Member
    Thank you.
    Time to take them out!
  7. ike72com
    ike72com Member
    Charleston SC
    are you replacing passenger side only?
    i recommend replacing as a pair if you,re not.
  8. 1973Ford
    1973Ford Member
    I replaced the driver's side last fall. I had to get some welding done on the passenger side and I just got to the suspension on this side.
    ike72com likes this.
