Lower gears...where?
Discussion in 'Technical' started by BadBrad73, Apr 4, 2004.
  1. BadBrad73
    BadBrad73 Member
    Rome, GA
    1973 Maverick
    What models/engine combinations typically have the lower gear ratios (higher numerically) for the ford 8 inch? Where to look for 3.25 and up?
  2. FredH
    FredH Member
    Seminole, FL
    69.5 Maverick
    Look to the Mustang II's. I found a set of 3.55's in one at a local junkyard.
  3. BadBrad73
    BadBrad73 Member
    Rome, GA
    1973 Maverick
    Thanks!
    Thank's for the info. Any particular models or engine combinations to look for? Do the 4 cylinder cars have 8 inch rears?
  4. Grabber75
    Grabber75 Member
    Mount Vernon, Ohio
    1975 Maverick Grabber
    no the 4 bangers had 7.5 rears in them......just look for the 4 lug wheels and keep on walkin' :D
  5. Craig Selvey
    All 1974 Mustangs with a V-6 had the 3.55 8" rear pumpkin. This will bolt right into your Maverick 8" rear axle housing.
  6. Grabber75
    Grabber75 Member
    Mount Vernon, Ohio
    but not a 4 cylinder......like i said.............
  7. Craig Selvey
    But the 1974 V-6 Mustangs would also be a 4-lug....so you wouldn't want to keep on walking past that.
  8. Grabber75
    Grabber75 Member
    Mount Vernon, Ohio
    but i thought they had the 7 3/4 ring gear in them?
  9. Craig Selvey
    Nope....8". That is where my last two 3.55 gears came from.
