lowering springs a hair uneven
Discussion in 'Technical' started by Racer_X, Apr 1, 2013.
  1. Racer_X
    Racer_X Maverick Hugger
    North Carolina
    1974 Maverick (1970 clone)
    i had installed a set of 1in lowering spring from mustangs unlimited (the blue ones) and after everything was put back togeather with all new suspension parts i noticed that the driverside spring was a little loose and the passenger side spring was good and tight, this is with the front suspension at full hang. i paid it no mind thinking that it would take time for them to settle. that was months ago and today while putting on the new 17's i noticed that that driver side spring still has a little bit of play in it at full hang, once down on full weight i noticed that the driver side is a hair lower than the passenger side. could this be due to the fact that the front springs havnt settled all the way? i thing once i start driving it again it should equal out on the front.
  2. 71gold
    I would think if the springs are the same # rate they should be the same height...:yup:
    the 2 sets I have are.
    do they have...numbers or paint markings...on them?
  3. Racer_X
    North Carolina
    not that i remember, i think joe dirt used the same ones i have on his mav
    it may be due to the fact i need an alignment done after replacing the whole front end
  4. Craig Selvey
    We have a winner!! You need to get an alignment before you can judge anything.
  5. Racer_X
    North Carolina
    yeah my baby is lookn a little bo-legged up front :D
  6. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Uneven rear springs can also make the front sit uneven.
  7. 71gold
    if it's a "spring issue" and they align the front end...then when you get the springs straightened out, you will need another alignment...:yup:
    I would check that everything is good first...(y)
    did you loosen/retighten the A frames when you set the car down when you did the front end work?
    ...I would remove both springs and verify they are the same rate/height...
  8. Racer_X
    North Carolina
    two alignments :hmmm: thought all i need is one, i had everything tourqed before i set it back down
  9. Bryant
    check to see if one front control arm sits lower than the other side when drooped. i dont care really about the springs when the front end is off the ground. the question is does the front end sit level on the ground?
    you may want to disconnect the sway bar from one side so it doesnt effect the side to side height. if it sits level i would not worry about the springs. if its not level and it corresponds to the loose spring vs tight spring then you know where your problem is.
  10. Racer_X
    North Carolina
    do i need to look at the upper or lower control arms?
