Lowering the maverick . . .
Discussion in 'General Maverick/Comet' started by mashori, Jun 11, 2011.
  1. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I'm wondering what a realistic drop in ride height would be. I drive the car every day in a metropolitan area. I race the car a lot as well so need a low stance. I have a deep sump oil pan and long tube headers.
  2. Streetdeacon
    Streetdeacon Streetdeacon
    Bellingham, WA
    1977 Maverick 2dr.
    I cut one coil in the front and left the rear where it was. :tiphat:
  3. Bryant
    you need an air ride suspension. just kidding. thanks for joining me and my family for my b-day.
    getting the coil overs for the front end will allow you to adjust the front end till you find what works best for you. 3" is considered by lots of car builders to be the lowest ground clearance that you can get away with. thats from the lowest part of your car which is the headers.
  4. CaptainComet
    I cut one coil and still have the original weak rear leafs. Never scraped a header and drove the car as my daily driver. Front tires are pretty low, too ... 215/60/15s. Always took it easy around speed bumps.
    The stance is shown below ... the green car.
  5. 71gold
    that is too low...it's below my screen...:rofl2:
  6. justin has a 74
    kentucky
    humn..... Im going to use 2 inch drop mustang fox springs. seems to be a good 10 inches off the ground with my motor in
  7. CaptainComet
    G' mornin' Frank.
    Thanks for the laugh. ;)
  8. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    I am actually gonna go get some blocks for the rear today and posibly cut the 6 cyl springs up front this weekend. In the rear I am gonna have some buddies sit on the trunk till its as low as I like and measure the drop then do the same for the front. I am more interested in how the tire/fenderwell opening looks.
  9. scooper77515
    FWIW...I have the 4-leaf heavy duty JC Whitney leaf springs on stock shackles, and used a 1" drop block.
    Front is pretty Frankensteined, and couldn't be replicated if you tried. If interested, you can check it out on my website for details. http://scooper77515.fordmaverick.net/july2005.htm
    Here is how high the springs sat before I cut them down...And those are my REAR tires on the front. Yes, there is a jack under there, but look closely, the yellow thing is the jack's pad, and it is lowered!!!
  10. injectedmav
    injectedmav Member
    Georgia
    I used 67 Mustang bigblock springs and had the same problem. Mine is also piecemealed together and would be difficult to replicate. For the record tho, a 1" block in the rear, 2 3/4 coils removed from the above mentioned springs, StreetorTrack UCA's with a 1" UCA pivot drop. It's 25.5" off the floor at the top edge of the arch in the rear wheel well and 24.75" at the top of the arch in the front. The lowest point on the car is the headers (6901 hookers) at 4". I'm with Bryant on the min of 3", some speed bumps here can be 3-4" high. Some local ordinances here also state a minimum ground clearance of 4-6"
  11. scooper77515
    I drug my headers all the time with 205/60r15 tires. Swapped them out for 215/60 and never hit anything again. Newest tires are 225/60
  12. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I ordered the coilover conversion which will mount to the UCA so I'll see how high it sits then. I have a lot of bump to worry about as well so we'll see how it all goes.
  13. Dave B
    I can't wait to see how it works, I'm going to order the same thing.
  14. indabebe
    indabebe Member
    86 nissan 720
    i was just looking at my comet today and i was also thinking of lowering the front a little. do you have a link on where you got your coilovers?
  15. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
