m/c fittings
Discussion in 'Technical' started by 71gold, Feb 1, 2007.
  1. 71gold
    this is kinda-sorta ...tec./parts wanted...
    i need some m/c fittings...(y)
    i can get the line fittings but no m/c fittings...:huh:
    ...frank...:bouncy:
  2. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    M/C = Master Cylinder ?
  3. 71gold
    m/c, p/s, a/c, p/b, ww/t, twd, 2dr, a/t, lh/s and :p
    yes...M/C = Master Cylinder
    ...Mikes' friend frank...:bouncy:
  4. bmcdaniel
    The local parts store has drawers full of brake fittings and adaptors to mate the lines up to the M/C. It's not an AutoZone or Advance, it's a REAL parts store.
  5. blugene
    Got mine at a Nappa...
  6. 71gold
    got your what? :huh: m/c fitting or one of them ...cheezy...adaptors:yikes:
    ...Genes' friend frank...:bouncy:
  7. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    they are the worse places to go sometimes.
    Auto zone asked me when i got my spark plugs if they spark plugs went into the BLOCK :hmmm: when was the last time a spark plug went into the block:idea: :hmmm:
    yeah id say any GOOD parts store should have fittings
  8. blugene
    Yea, I got an adaptor...:(
    I guess being that your wife supports you, you can afford a "m/c fitting":p . Sure hope it fits your hole right.:biglaugh:
  9. 71gold
    i can find all kind of ...brake line fittings...but none to fit the m/c. :hmmm:
    ...frank...:bouncy:
  10. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    I got mine from the junkyard. They don't wear out. Unless someone rounded them with a wrench or pliers, they should be fine.....
  11. Kelly Evans
    Kelly Evans Member
    Centerville GA
    1969 1/2 Maverick
    Hey Frank ...Finally got back on to post, would the old 69.5 that you used to have still have the fittings? Its at a friends if you can remember if there was anything usable there? Give me a call. Kelly
  12. 71gold
    ...call Kelly, who ??? :huh: do i know you :hmmm: :Welcome: back :thumbs2: .
    good idea :yup: .let me see if i can find some new ones first...that way we will have a source for later porjects...
    ...Kellys friend Frank...:bouncy:
  13. 71gold
    got my ...new...M/C fitting today.:bananaman :bananaman
    took the old line by his shop and he cut the old fitting off and reflared the line with the new fitting for me...$3 bucks... (y)
    ...frank...:bouncy:
  14. blugene
    I did the same but I could only find one of the sizes. Did you get it double flared? That is the correct way...
  15. blugene
    Bleed them brakes yet?...
