mallory distributor questions
Discussion in 'Technical' started by 1973GOAT, Nov 1, 2009.
  1. 1973GOAT
    1973GOAT Member
    Georgia
    Maverick
    just got a used Mallory from a friend of mine was in working order and looks new. Is it as simple and drop in and go or do I need the Mallory ignition module, or do I cut and splice the wires. Any help would be great!
  2. Mavman72
    First determine if the dist you have is plug and play (stand alone unit) or if it needs a box to operate,then hook it up accordingly.
    You can go to malloryperformance.com and copy instructions for your app.
  3. 1973GOAT
    1973GOAT Member
    Georgia
    Maverick
    how do you tell, It looks a lot like a factory dist , but the wires will not connect to the factory harness
  4. Mavman72
    No PN# on it huh?? Its probably a duraspark style replacement.If so it requires a DS box to work.Check out the mallory site...Time to go hunting for info.Sorry I cant give you more info but W/O a proper PN# I dont want to send you in the wrong direction.
  5. 1973GOAT
    1973GOAT Member
    Georgia
    Maverick
    Its a Mallory Breakerless part # 5755301a if that help , I have looked all over for info on it and cant find anything.
  6. Mavman72
    A quick look didnt turn up anything for me either.Call Mallory directly (216)688-8300
    And see what they say.Should get the help you need.Good luck!!!
  7. rthomas771
