Mallory Max Fire
Discussion in 'Technical' started by Blown 5.0, Dec 23, 2008.
  1. Blown 5.0
    MS.
    1974 Maverick
    I thought some might find this interesting. This is a fully adjustable, Self contained 4 wire dizzy some might find interesting. Needs no ignition box, Hook up is simple. Also has a built in map sensor for BOOST retard or vacuum advance. I installed one yesterday on a Blown GM. I was impressed with the ease of setup and programming. It seemed to work fine too. This could be a good simple addition to anyone's motor.
    http://store.summitracing.com/partdetail.asp?autofilter=1&part=MAA%2D2255104&N=700+400249+4294881256+4294908331+4294840126+4294881236+115&autoview=sku
  2. bmcdaniel
    Please keep us informed if any problems develop. I know of only one other person that has installed one of these, on a NA 347, and after just a couple days he started having problems with it not starting. I guess I'm just a little leary about having all of the electronics sitting right on top of a hot engine.
  3. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Does it have a Rev limiter also?
  4. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    it has a single stage rev limiter
  5. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    Cool Accell....er uh I mean Jacobs Electronics...uh.....Mr Gasket....I mean Mallory makes a good distributor, I wondered about how they would run.... :thumbs2:
  6. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    What does this mean? Is it like you just set it for 6200 RPM & it will never let the car rev over that.
  7. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    yep it will interup the ignition also known as breaking up the ignition
    where ever you set the rpm at
