manifold vacuum for modulator on transmission
Discussion in 'Technical' started by xpsnake, Aug 7, 2006.
  1. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    I have a weiand 8011 intake, attached is a picture of it with a port circled, can I put a fitting here and run my vacuum modulator from it?
  2. igo1090
    igo1090 Member
    catonsville, md
    yes, but i usually prefer a carb port that is below the throttle blades for more consistent signal.
  3. mean_maverick
    I Have Mine Run From There On My Edelbrock Intake And Works Just Fine
  4. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    My edelbrock as a hole back side of the intake carb mounting flange. I ran mine there works fine!!!! I ran mine off the carb and it haunted around between 2nd and third to much. I have a stall converter may have affected it but it made a difference.
