manual disc brakes
Discussion in 'Technical' started by one cool ride, Feb 4, 2007.
  1. one cool ride
    one cool ride Member
    armagh pa
    73 two door
    Hi im new here this page is great lots of info lots of help and i do need help. I want to put manual disc brakes on the front of my 73 maverick it now has drums on it can i buy 74 too 77 disc caliper and rotors for a bolt on fit or will it not bolt on. thanks.
  2. Ryan
    Ryan Ford Addict
    Phoenix Az.
    you would also need the spindles. If you fin one in the junkyard you would just want to knock off the spindle from the ball joints and tie rod and take the whole thing. You should probably grab the steel brake lines that run down the frame too.
  3. one cool ride
    armagh pa
    73 two door
    thanks
    thanks for your help
  4. mleega1
    mleega1 MAVERICK MARK
    Lagrange, GA
    1971 Maverick 2015 F150 2003 Explorer
    Get the proportioning valve as well. :idea:
  5. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Early Granada and Mercury Monarc are the same and will bolt right up, too.
  6. 98truck
    98truck Member
    london Canada
    1970 Grabber Maverick
    what about the master cylinder, which one would you use. If you run 4 wheel disk brakes would you not need a different m/c. I put 4 wheel disk branks on my 70 maverick, but I need to know what m/c too use?
    Thanks George
  7. mean_maverick
    i have seen some people fab up a master cylinder from a 70's/80's model Corvette with 4 wheel disc. seems to work fine for them...
  8. Dave B
    I'm using the stock drum master cylinder on my 73 that I put disc's on with no problems. You could look into the Geo Metro conversion.
  9. mean_maverick
    but will the drum m/c send enough pressure to the front? because i believe that the disc brakes should require more pressure to operate efficiently, over drum brakes. this is just what i have always understood it to be... :huh:
  10. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    i did the same,only mine are four piston calipers. no problems here.i did have to change one end on my stock brakeline.
  11. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    The pressure is fine, but you need the larger reservoir for the fluid displacement associated with disc brake calipers...
  12. bmcdaniel
    And the drum/drum MC doesn't have the correct residual pressure valve for the discs.
  13. T.L.
    T.L. Banned
    Southern Colorado
    Discs do not use a residual pressure valve, except in cars (like old street rods) that have the master cylinder mounted lower than the calipers/wheel cylinders.
    Also; I "don't think" (I don't know for sure though) the Maverick/Comet drum brake master cylinder has residual pressure valves either...
  14. mean_maverick
    well this is something new to me......
  15. ford84stepside
    Berry Alabama
    This is correct. You will need a 74 or later Master with the large and small chambers. The early ones have both chambers the same size and you run the risk of running out of fluid and pushing air into the disc calipers, not good!
