Manual Steering Setup NEED HELP
Discussion in 'General Maverick/Comet' started by rdog348, Aug 6, 2013.
  1. rdog348
    rdog348 Member
    Marion, N.C.
    1971 Grabber
    I am converting to manual steering and a guy I know has a '71 inline 6 car with manual steering.. He said he would let me have the steering but says it won't work with my V8 car because it is from an inline 6 car, is this true? I need help fast because I am wanting to put the steering in before the motor goes in. Thanks to anyone with an answer. :bowdown:
  2. Dave B
    It'll work. Get the idler arm, the Center link, and the pitman arm off the steering box.
  3. rdog348
    rdog348 Member
    Marion, N.C.
    1971 Grabber
    Thanks a ton for the quick reply. He said I can have everything that is related to turning the car, should I use the manual steering box or the power steering box?
  4. Craig Selvey
    As Dave said, it will all work.
    I would personally recommend using the manual steering gear box as well. With the power steering gear box, it will be harder to steer the car and require more effort.
  5. rdog348
    rdog348 Member
    Marion, N.C.
    1971 Grabber
    Is there any difference between a 6 cylinder steering box and a v8 steering box?
  6. Dave B
    Nope, not that I've seen.....
  7. Rando76
    Rando76 Member
    Claremore, OK
    I converted my V-8 '73 to manual using everything from a six cylinder car. No problems. I used everything from the steering box down.
  8. rdog348
    rdog348 Member
    Marion, N.C.
    1971 Grabber
    Thanks that helps a lot. He says the drag link is smaller in diameter and the steering box will have too much slop in it because its from a six cylinder.. :huh:
  9. mercgt73
    mercgt73 Member
    Just get everything and then you can decide if it is too small or too sloppy.
  10. Dave B
    "He" obviously knows more than us....
  11. Craig Selvey
    There is absolultely no difference. Case closed.
    :D
  12. rdog348
    rdog348 Member
    Marion, N.C.
    1971 Grabber
    Thanks Craig!
  13. rthomas771
    Six cylinder cars did use different size parts back in the 60's. By the time Mavericks roll off the line they used the same.
  14. Mavaholic
    I would keep your power steering box for 2 reasons. Because of the power assist, it will have less wear than the manual box. Secondly, it has a quicker ratio. All those who complain about hard to turn in a parking lots are just pansies. They probably drive automatics too. :rofl2:
  15. tody
    tody Member
    cologne, germany
    my thoughts exactly. :thumbs2:
