manual steering swap question
Discussion in 'Technical' started by jnew42, May 9, 2011.
  1. jnew42
    jnew42 Member
    Sacramento, CA
    65 Comet caliente 4 door
    I have a 65 with factory power steering, the box is blown and everything leaks p/s fluid so I just want to swap it out with a manual steering box from Borgeson. Do power steering boxes and manual steering boxes have the same number of splines on the shaft? I realize I'll have to do a little more than just swap the boxes, I just need to know if it'll even work with my column.
  2. rthomas771
    As long as it is the 1" sector shaft. '64 V8's had 1-1/8" sector. '65 went back to the 1". All 6 cylinder cars, no matter what year got the 1"
  3. TOPORANGER
    TOPORANGER Member
    WISCONSIN
    Try to get the lowest turns lock to lock, box you can.
