Manual trannies that mount to a 250?
Discussion in 'Transmissions' started by Crusader, Mar 21, 2010.
  1. Crusader
    Crusader Member
    Oregon
    1974 Maverick
    So I've decided against doing the V8 swap for now for fuel economy reasons, so instead I will build up the 250 and I'd like to put a manual transmission in there too, preferably a 5 speed. Does the T5 work with a 250 I6? If so, does anyone have a recommended way to acquire a T5?
    Thanks!
  2. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    people use T5's on the fordsix website if I remember right.
  3. Ford Guy
    Ford Guy Member
    Pinnacle, NC
    1973 Grabber
    A T5 should work because they bolt to 302's and I'm pretty sure the 250's and the 302's use the same bellhousing.
  4. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    yea, I think your straight. I was looking into the same switch some. If I remember right, and please someone correct me if I'm wrong, there are two different bellhousings for the T5 that would mount up to the I6. If I have time today I'll find some of the articles and threads. I don't wanna assume that I remember too much from them.
  5. rthomas771
    The T-5 will need the deep T-5 bellhousing because of the length of the input shaft or buy an adapter to go between the transmission and bellhousing. Using an adapter will let you keep factory clutch setup.
  6. PaulS
    The 250 uses the same bellhousing as the 302.
    Since there is a bellhousing for the 302 it will work.
    The flywheel and clutch has to be for the six cylinder due to balance issues but the transmissions will be the same as the V-8.
  7. rthomas771
    This will get the transmission in the car but not the clutch linkage. The factory linkage will not work. Another $200+ will be spent to convert to cable linkage.
