manual transmission swap
Discussion in 'General Maverick/Comet' started by redfivexw, Apr 29, 2016.
  1. redfivexw
    redfivexw Member
    I have a 70 maverick with a 3 speed column shifter. I hate the 3 speed, love the car. I was considering doing a t5 swap. I have a 95 ranger with the 5 speed M50D. The frame broke on my ranger, wondering if it is possible to use the m50D transmission in the maverick, anyone who has any ideas please post before i junk the ranger.
  2. Krazy Comet
    I'm fairly those light duty versions in Ranger won't fit anything but the 4cyl or small v6... There were some HD versions used behind 5.0 & 3.8/4.2 V6 that could be used if you have a 250, or 302, otherwise you'd need a adapter(if such exists)... Also I believe all those trans use a internal throwout bearing hydraulic clutch, that would require plumbing if you had one that actually fit...
  3. mvw66gt
    mvw66gt Member
    Arthurdale, West Virginia
    71 Comet GT
    That M5OD transmission is a big transmission too. Would be a tough fit in a Maverick. Plus the shifter tower coming out of the top. Would have to have a custom made shift handle.
