I just purchased a new spoiler from MAS and it is not even close to fitting. Does anyone know if there was more than one front Valance on a 73 or did I just receive the wrong spoiler?
Only one valance for 73 and it is a one year only piece. I have a MAS spoiler on mine, we had to start in the middle and work our way out.
Mine sat in the box for several years as I thought it would never fit. A friend of mine who is a body man came over and we put it on. You can also check out the one that Chuck at the Maverick Connections sells. http://cgi.ebay.com/ebaymotors/1970...008QQitemZ180129973031QQrdZ1QQsspagenameZWDVW
I have used several of these MAS spoilers. They have never fit flush right out of the box as you would like them to. Like Allan said, you have to find a starting point in the middle. Drill and install the center screw. I then slowly work my way outward from side to side drilling and installing a screw about every 8 inches. The valance panel will move quite a bit and will fit better than you think when you get finished. I never did get one to fit real well at the sides though. Good luck...you'll need it.
THe 73 valance is different than the 70-72. Unless they have one specifically for the 73, it's not going to fit.
have installed three of them (all MAS) each one was installed off the car on a work bench, used # 10 screws and nuts with lock washers topped with acron nuts. used clamps to hold it in place, drilled center first, then outward one side at a time, all came out just fine!I'm on the road right now, (Richmond, VA.) will be home late Tuesday, e-mail me and I'll try and send you some pics.
When I got mine from MAS they said it only would fit 70-72. I would check with them again and find out. GOOD LUCK!
