master cylinder push rod..
Discussion in 'Technical' started by noodledood2, Jan 3, 2015.
  1. noodledood2
    noodledood2 Member
    Turlock, CA
    1971 maverick 302
    I have recently installed granada front disks with a master cylinder and distribution block (from the granada) into my 71 mav. I now have a problem with the brake pedal height. The pushrod im using came with the mastercylinder but it did not seem to be much longer (maybe 1/4 of an inch, if that) than the stock maverick push rod. Do i have a pushrod problem or is it perhaps the wrong master cylinder. I would highly prefer not to have to replace the MC. It is specific to the 77 granada (power brakes).
  2. tody
    tody Member
    cologne, germany
    you have a pushrod problem. use the one that was on the car before.
    Crazy Larry likes this.
  3. noodledood2
    noodledood2 Member
    Turlock, CA
    1971 maverick 302
    okay thanks
  4. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    A quarter-inch difference in the pushrod actually makes a big difference in the pedal height.
    It has to do with geometry. The pedal will be quite a bit higher than a quarter-inch.
  5. 71gold
    or a Mustang parts store will have an adjustable rod.
  6. bmcdaniel
    bmcdaniel Senile Member
    They almost always supply the longer Mustang rod with new master cylinders. In the past I've cut 3/8" out of the rod and welded back together. Last time I put a 3/8" spacer between the firewall and the master cylinder.
  7. mojo
    1.) After the spacers were put in; U have to use longer mounting bolts for the master?
    2.) Spacer/s cover entire mounting flange or just at mounting holes?
    3.)How much approx. did it lower brake pedal?
    I have some spacers behind my MC, were there when I replaced MC but nowhere like 3/8" more like 1/8". I have a adj. push rod I plan on using to lower the pedal when I get around to it this spring. I am wondering the best option, when/if I can't get the rod out of the MC w/o damaging it..
  8. bmcdaniel
    Spacers are just behind the mounting holes. I used longer grade 8 bolts and screwed them in from the engine compartment. The brake pedal is now the same height as the clutch pedal.
  9. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Just use the adjustable pushrod & everything will be fine. Don't make it more complicated than it needs to be.
  10. mojo
    Point well taken!
