Maverick A/C Mister Feature
Discussion in 'Technical' started by BrewDaddyDave, Oct 1, 2015.
  1. BrewDaddyDave
    BrewDaddyDave Member
    Miami, FL
    1975 Ford Maverick
    For some odd reason when I have the AC blowing and make a turn bits of water fly out from the vents.
    At the same time my aftermarket pioneer radio will change stations and volume.
    I've noticed a yellowish liquid occasionally dripping onto the floor from under the dash as well. Could be dirty water as it has no distinct aroma.
    Is my Mav waterlogged? It has been raining hard the past few days.
  2. Craig Selvey
    If yours is a factory AC car, make sure the drain hose is actually "draining" the box.
  3. maverick1970
    maverick1970 MCG State Rep
    Missouri
    The drain tube is likely clogged, causing the box to fill up with moisture from normal AC operation. The drain comes out on the passenger side of the transmission tunnel in the flared section.
  4. BrewDaddyDave
    Miami, FL
    1975 Ford Maverick
    Well wouldn't ya know...I drove over a bump on these crappy Miami roads and the AC stopped blowing. I guess it's Murphy's Law time.
  5. Krazy Comet
    Check the fuses... If the sloshin' water got into the squirrel cage(blower), the extra load on motor could blow the fuse... Requires a 30A mp...
  6. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    That was the ultra rare water cooled ac, only available with the Boss 302 engine.
