Hello all, Just sealed my fuel tank and replaced the fuel sending unit but the o ring is tall and I cannot seem to get the lock ring in place. Is there a trick to this that I’m missing? It’s a 70.
The o-ring is tall because there is a groove in the tank it fits into. Put some grease in that groove and push the o-ring into it to hold it in place. Insert the sender and then you should be able to get the lock ring on and drive it around with a screwdriver.
So after much effort I finally reviewed my post and saw the reply about the groove ♂️ I removed the stuck o ring and it went right together! Thank you for the help and support!
