maverick hood for comet
Discussion in 'Parts Interchange' started by RUBEN VARGAS, Feb 3, 2005.
  1. RUBEN VARGAS
    RUBEN VARGAS Member
    Houston, Texas
    1974 Mercury Comet
    2/3/05
    Is a maverick hood the same as a comet hood? :hmmm: I need a hood for my
    comet and the junk yard I believe only has maverick hoods.
    RVARGAS8@HOUSTON.RR.COM
  2. don graham
    maverick and comets are different hoods.
  3. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    I think if you changed the grill to a maverick grill the rest will be OK..someone help me with this to make sure.
  4. Mavaholic
    It will bolt on but the grill will stick out past the Maverick hood quite a bit. Wont look right IMO.
  5. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    where is this junk yard i would like to check it out. i have a couple of extra maverick hoods, if you want to try and see what it would look like, but they are different.
  6. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    It won't fit....
    ...without changing the grill and latch support etc.
    '71-'72 has a different front bumper too.
    It won't run right either after putting it on.
    Comets were built much better than Mavericks
    and the Maverick hood will make it run poorly.
    :biglaugh:
    Seth
