maverick rearend question
Discussion in 'General Maverick/Comet' started by SD44, Dec 6, 2007.
  1. SD44
    SD44 New Member
    mississippi
    hello,
    what year model maverick rearends were the same as the 72 maverick?
    got a little pinto rearend swap project going on. had someone tell us that he put a 72 rearend under his pinto no problem. we don't have a 72 model, but have several other models. (y)
  2. Craig Selvey
    Pinto is different lug bolt pattern.
  3. SD44
    SD44 New Member
    mississippi
    what we're doing is a 5 bolt lug conversion. there are aftermarket rotors that can be used to convert the front, but the rearend has to be changed to go to 5 lug. we have a sizable salvage yard with a few mavericks; as stated, someone told us he put a 72 maverick rearend under his. we don't have a 72, but have some others so i need to know what years are the same as the 72.
    thanks
  4. Thack
    Thack vision advicator
    Moreno Valley Ca
    all the mavericks have the same type rear end 8" with the same width, some of the small 6's have a 7.5 I think that is what you are asking for. You have a pinto and you are swaping to five lug?
  5. SD44
    SD44 New Member
    mississippi
    actually it is my father, he has a thing for the pintos.:hmmm:
    don't understand why.......
  6. newtoford
    newtoford Member
    New Castle Delaware
    a 72 6cyl maverick will have a 4 lug 8'' rear, v8's have 5 lug 8''s
  7. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I know the Mav rear is a direct swap to a Stang 2, so if the Pinto rear is identical, which it probably is, then you're good to go with any 5 lug Maverick rear.
  8. don graham
    i believe after 73 they were all 5 lug. there all the same width.:)
  9. SD44
    SD44 New Member
    mississippi
    guys thanks a ton, this is the exact information that i've been looking for.
    and yes, from everything i've read the mustang II is the same platform and drivetrain as the pintos.
  10. Jamie Miles
    Alto, GA
    I've had a few
    Just stay away from '70 Mavericks. '71-'72 6 cylinder cars were 4 lug (4 x 4.5). '71-'72 V8 cars were 5 lug (5 x 4.5 pattern), but the "hub" in the center of the axle was a little smaller from what I have seen. All Mavericks from '73 and up were 5 lug regardless of engine, and the "hub" in the center of the rear axle is a little larger. Mavericks came with two gear ratio's, 2.79:1, and 3.00:1. The easiest way to tell which gear you are getting is to look at the tag inside the drivers side door. Under the "Axle" code, a 3 means 2.79:1, and a 6 means 3.00:1.
  11. PaulS
    Jamie,
    Not all the 73s had 5 lug. I have one with 4 lug wheels and a 250 six.
    I think Ford uses what ever parts they had left over. I do know there is an early and late 73 so maybe the one I have is an early 73... I haven't checked.
  12. Jamie Miles
    Alto, GA
    I've had a few
    Hmm... I have never heard of nor seen a 4 lug '73. I have an early and late '73, both 250 cars, both are 5 lug. Sounds like we need Mr. Craig Selvey to chime in.
  13. Craig Selvey
    I've already chimed in....do a search. :D
