maverick weight for each year
Discussion in 'Technical' started by pipman76, Jan 1, 2011.
  1. pipman76
    pipman76 Member
    alabama
    1972 mav
    i have a 70 maverick and if what i found on the internet is correct the 70 was the lightest at 2501
    1971 2624
    1971 2679-grabber
    1972 2681
    1972 2736-grabber
    1973 2757
    1973 2812-grabber
    i know the big bumper cars should weigh more by can anyone tell me why the 70 is so light at 2501
  2. brainsboy
    brainsboy Member
    Tampa
    I saw those numbers too and was wondering if those were a curb weight, with fuel and spare tire. Also I think those were for a 6 not a V8.
  3. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
    Several reasons for that. The #1 is the front steering is lighter duty than the rest. The gas tank drops in so there is no floor in the trunk. It is really a different car from the rest, and still be the same. And like the 71 and 72 there are no reinforcements in the doors for side impact.
  4. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Can't see a Grabber that much heavier than a standard Maverick. Maybe 10-15 lbs for the deck spoiler, and that's stretching it.....
  5. pipman76
    pipman76 Member
    alabama
    1972 mav
    i agree with those numbers being for I-6 cars but hey even with A ALUMINUM HEADED SMALLBLOCK they ar estill light little cars.as far as grabbers weighing in more only things i can think of that add weight is the belly bar .from my experience the grabber hoods also weigh more than flat hoods .you can also add 2 ounces for the stripes..LOL
  6. injectedmav
    injectedmav Member
    Georgia
    less insulation, no ac, no power steering, bench seats, column shift, small brakes (9"), small rear axle, six cyl suspension parts are lighter too, etc. I could definitely see a couple of hundred pounds.
  7. maverick75
    My local newspaper did an article on mavericks and they listed the weight for a 74. It was 2781(I6) 2844(V8). Heres a link to the article: 74mavarticle_original.jpg
    Superdave1 likes this.
  8. rthomas771
    I always thought the V8 weighs 65 more pounds than the 6 cyl...not 63. Now I really feel like a fool. :slap:
  9. mav1970
    You have to add the weight of an ignition pod to the 2501 for the 69.5 cars :biglaugh:
  10. scooper77515
    For what it is worth, I took my 74 to a junkyard and put it on the scale. With me in it, and carrying an extra set of slicks, full toolbox, near-full tank of gas, and my 200 lb butt in it, it scaled out at 2980.
    This is a 74 with one lighter 73' door, small bumpers, and a 5.0 installed.
    So 2800 lbs plus or minus.
    Or WAY minus with less gas and without all the extra crap I tend to carry around with me.
  11. ryanb
    ryanb Member
    Portland, Oregon
    '72 2D Maverick, '85 F150 Short Wide, '07 Husqvarna SMR450, 2015 Yama FZ09
    I just took my 72 2 door to be weighed. It's got a 302, cast heads and intake, with nothing but a racing seat for me for the interior, it came to 2600 with me in it. Pretty impressive IMO. Of course I only weigh about 135 pounds so...
  12. scooper77515
    WOW!!! The interior plus "what" makes your 72 400 lbs lighter?
    I know my door with the cross brace in it is a good 50 lbs heavier than the 73 door without it. I have full interior for another couple hundred lbs, max.
    I wonder what else is lighter about your 72?
  13. rthomas771
    Can't be 50 pounds. Here is a '75 door complete with glass and arm rest and it tipping the scale at 74 lbs. I know it takes 2 people to hang a 72 door on a Comet and the door weighed more than 25 lbs.
  14. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Good thing I'm not a hardcore drag racer. But back when I was drag racing I weighed my car at the track. Without me in it, with half tank of gas it weighed 3210. I've done nothing but add weight to it since I got it. That was back when I had iron heads on it and a c4. It has a 9" rear, full interior, abunch of wood in the trunk for the sub box and amp racks. SInce then I have swapped out the c4 for an AOD and added 7 way power seats from a Lincoln Mark VII. probably added another hundred pounds or so but have aluminum heads now. still probably over 3300 lbs.
  15. ryanb
    ryanb Member
    Portland, Oregon
    Oh, and I forgot to mention I took out the heater/defroster box, but thats about all I can think of that I changed. It's missing the heater, carpet, seats, door panels, ps pump, ram etc, spare tire, its got steel wheels, and it had a full tank of gas when I weighed it.
    The front end came out to be 1500 lbs, and the back came out to be 1100 lbs. It's really front heavy, but If I moved my battery to the trunk, got an aluminum intake, heads, and wheels, put in an aluminum or poly fuel cell, plus I siphoned my gas down to about 5 gallons, and took out the headliner, and did a few other things to lighten up I might be able to get it down to about 2400 or less with me in it. That would be amazing!
    But... I still have to put in my rear firewall, and my 8 point roll bar, and my sub connectors.
