Maverick weight ?
Discussion in 'Drag Racing' started by Groundhawg, Jan 21, 2013.
  1. Groundhawg
    Groundhawg New Member
    Seven mile ohio
    1972 maverick. 1979 mustang
    I was wondering if any one had any ideal what a 1972 maverick weights with an aje k member conversion and a Alum head Windsor car does have a moly cage manual rack and aero space brakes
  2. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Weight of vehicle
    Save yourself some time .. Take it to a scale where they weigh trucks and get an ACCURATE weight ..
  3. Groundhawg
    Seven mile ohio
    I was just tring to figure out a base wieght motor and trans are not in the car yet thanks
  4. bmcdaniel
    This same question has been asked a couple of other times very recently, if you do a search... But, as mentioned, with all of the different options and customizations the only way to know is to weigh it. I've seen very similar cars weigh several hundred pounds different.
  5. groberts101
    groberts101 Member
    Minneapolis, MN
    full interior version would likely be around.. 3,200'ish wet?
    stripped down.. maybe 3,000'ish?
    lek those guy's already said though.. every parts combo and design will be different by a hundred lbs or more.
  6. ray-g151
    ray-g151 Member
    Hatboro, PA
    1971 Maverick 412w , 1969 Cougar 427w, 1973 Maverick 306w
    My car was just over 2800 w/o me. Thats with a Dart 8.2, mild steel cage, glass hood, exhaust, stock dash, and caltracs. With the weight savings of a chromoly cage and aje kit and adding about 50 lbs for a 351, it should be under 2700 lbs w/o driver.
  7. Groundhawg
    Seven mile ohio
    Thanks for the help hopefully I'll know for sure soon
