Maverick?
Discussion in 'Maverick/Comet Projects' started by ncmaverick1977, May 28, 2011.
  1. ncmaverick1977
    ncmaverick1977 Member
    Burlington, Ia
    1977 Maverick
    Do you ever wonder if we're all working on the same kind of car? I've done some looking on the forum for header fitment so I know what many people are using. My hedmann 88400 shorties (which have been used by people on the forum) went in slick as a whistle. However, I won't be making a left turn any time soon as the pitman arm cuts across about 2 inches below the collector. WTH?
  2. Craig Selvey
    It takes a little finess to get a pipe up in there. I seem to recall an "ear" on the tranny bellhousing that needs to be cut-off for more pipe clearance.
  3. ncmaverick1977
    Burlington, Ia
    1977 Maverick
    Whew! I'd sure like to see a finished install pic. I don't see how these could work. Maybe I'll remove my pitman arm....who needs to turn? They're old headers from another project so I'm not out anything. Ironically they're from the last time I swapped to a t5 because my hookers wouldn't fit with the cable clutch. Those were probably the 6901's. Unfortunately I scrapped them. Lots of people seem to be using the hookers. Old Henry didn't secretly change every third Mav. on the assembly line I hope.
  4. Craig Selvey
    They will work. I had them on my car. I had some pictures and a thread posted on here about it.
  5. ncmaverick1977
    Burlington, Ia
    1977 Maverick
    Thanks, Craig. I shimmed up my trans. so I don't have much more space before the t-5 hits the tunnel. It's still blocked quite a bit, but I'm starting to see how it might work with a bit of tweaking.
  6. maverick75
  7. ncmaverick1977
    Burlington, Ia
    1977 Maverick
    Thanks. There's hope. I'll finish the engine/trans. conversion and take it to the muffler shop.
  8. ncmaverick1977
    Burlington, Ia
    1977 Maverick
    Here's what I did with my headers. I still measured wrong and had to ding the driver's side. I decided to change the pass. side while I was at it.
