McCord head gaskets?
Discussion in 'Technical' started by HadaGrabberonce, Apr 17, 2020.
  1. HadaGrabberonce
    HadaGrabberonce Member
    Talcott WV
    1973 Maverick 302 C4 3.55 Tractionlok Granada disc brake conversion Small front bumper
    I recently removed the heads on my 73 302. There was no indication that the heads had ever been off but the head gaskets were McCord brand and had no Ford part numbers. Did Ford use this brand at the factory or is this an aftermarket set?
  2. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    McCord is an aftermarket brand.
  3. Krazy Comet
    I'm not sure about McCord but someone had to make gaskets for Ford, GM etc. I know it was common to find Victor gaskets in Ford engines. Suppliers that sell parts commonly found in aftermarket, often supply OEM as well.
  4. HadaGrabberonce
    Talcott WV
    I think Ford may have used some McCords but these probably are aftermarket. At first I thought the heads had never been off but upon closer examination it is now obvious the car had a valve job at some point. At least one intake valve had been replaced. At any rate it has Fel-pro head gaskets on it now.
