Mechanical fuel pump needed . . .
Discussion in 'Technical' started by mashori, Oct 15, 2009.
  1. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Getting ready to install nitrous on the stock 302 and need some recommendations as to which mechanical fuel pump to get.
    I would like to use it on this engine and later on hopefully on the 331 that I'm building which is gonna have a supercharger on it.
    I need to figure out which flow rate and what PSI I need.
  2. PaulS
    My advice is to run a separate electric pump for the nitrous system.
    Regulate it to the pressure that your nitrous needs and you won't have problems with burnt pistons.
  3. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    if I need something for the supercahrger, can I just go with a mechanical, would it be sufficient?
  4. Blown 5.0
    MS.
    1974 Maverick
    X2 what Pauls said. You need a separate fuel system if you gonna be serious with N20. And preferably a return style system, As if you dead head when the nitrous is first activated it will be rich due to the dead head pressure. There are several good mechanical pumps out there, they just ain't cheap. I would recommend one with no less than 110 gph. http://www.summitracing.com/parts/EDL-1725/
    That pump is the minimum i would recommend, I ran one of these pumps (actually several of these pumps) for several years. They just don't last very long is the only draw back. I now run a BG 220 gph pump. This will be the next pump i get, http://www.summitracing.com/parts/RPU-1701/ But this pump requires a regulator as well as a return system. I prefer a mechanical pump due to shall i say, Giving the engine what it needs without running wide open all the time (electric pump, Guess I'm still ole school on this one) And besides if you have a electric pump and mechanical you will always be able to make it home if one quits. ( been there). And you can get the bottom feed kit for the edelbrock if space is limited as on my car. Here is one other thing i recommend for the N20 system, I wouldnt leave home without one. http://www.summitracing.com/parts/NOS-15670NOS/
  5. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    when i put the nitrous to to my engine i plan to run a 1 gallon tank full of 110 under the hood with a separate holley blue and bypass regulator.i plan to have the fuel pump turn on when i arm the system,also a fuel pressure switch.eh, maybe i am paranoid.for the engine i run a holley red.
  6. Bryant
    the blue flows more than the red pump. i cant see nitrous needing more fuel volume than the motor. unless your running a 300 hp shot or biger. also when the motor is accelerateing on nitrous it uses more fuel from the carb at the same time. i would sugest useing a blue on both systems.
  7. bmcdaniel
    Guys have been running blowers on cars longer than they've been running electric pumps...
  8. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I couldn't find a legitimate reason not to use a mechanical pump . . . I was wondering if anyone has any info or advice on this particular Holley mechanical pump http://www.holley.com/12-289-25.asp
    About $250 which is a lot but it's rebuildable and I don't need a pressure regulator which is nice.
  9. sierra grabber
    sierra grabber Certifiable
    northern nevada
    did you find a rebuild kit for that one to rebuild it? im not seeing it, and if that is not available get something else....if you have could you post a link?
  10. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    why would I need the rebuild kit? I will be purchasing new. Unless you mean for future, when I may need to rebuild it? I'll look and see what I'll find.
  11. Bryant
  12. sierra grabber
    northern nevada
    looking at all of these makes me want to switch to electric. the only one i dont see with that crappy style diaphragm is the $300 one blown posted. so far the one i have is the second one of that style and the last one started leaking out the side of where the diaphragm is, in a stream. the new\replacement is starting to show signs of leakage now. both have only been run for a very few miles as opposed to the one that came from the factory having run over 200k. at least with the electrics i can set them up out of the engine compartment to not spray gas everywhere >(
  13. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    cool Bryant, thanks, looks like I'll be around $200 with that one and the fuel regulator.
