Metro brake booster Questions
Discussion in 'Technical' started by Ryan, Oct 4, 2010.
  1. Ryan
    Ryan Ford Addict
    Phoenix Az.
    I did a search and looked through the tech articles and couldn't find the answer to my questions.
    I keep hearing about the Metro booster. Who has one on their car? I was wondering if the master cylinder I have now from a 74 mav w/front disc will bolt to the master cylinder or will I need to get a metro master cylinder and adapt brake lines. Also what mods are needed to the pedal rod, use the mav rod or metro rod?
  2. Dave B
    I was playing with one a few years ago, I had it bolted up, I was just having a issue with finding a rod to go from the booster to the master.
  3. diddie
    diddie Member
    indiana
    two 1977 Maverick 2drs.
    this is info i have been looking for as well! are we talking GEO METRO boster and master because lines and fabwork with rod is not a problem. just looking for somthing that will fit and have good pressure to the calipers on a four wheel disc sys.
  4. maverick75
    Theres a lot of falcon guys running them. I havent ever seen any maverick with them, but im going to try to use one. Im not dead set on it though, im going to take measurements of several cars at the junkyard to see if any will work better.
  5. maverick75
  6. Dave B
  7. diddie
    diddie Member
    indiana
    Thanks for this info guys! looks like what i've been looking for. Ive been checking alot of cars in and out of our shop, and at the local yards! the only thing i've came up with as a possibility is a Saturn SL2 thin booster and short master but booster is to big around for my application using FI sys. with plenum it would interfear.
  8. maverick75
    flip the plenum around. Throttle body on the drivers side.
  9. diddie
    diddie Member
    indiana
    sounds like a possibilaty but alot of other mods would be included with that :hmmm: got me thinkin thow
  10. maverick75
    ive seen plenty of them done like that. Wouldnt you just need to extend the harness?
  11. rthomas771
    The Geo master cylinder does not meter, proportion or provide residual check valves. It will work under light duty braking situations. It might not work well under panic stops and your rear wheel cylinders will not last unless you put a residual check valve inline.
  12. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Did the 4 bolts for the booster match up with the 4 bolts for our pedal assembly? The link didn't mention drilling holes so I think it bolted up and just needed the center hole opened up. Dave Are you saying you had room between the firewall and shock tower to fit the Metro booster with a maverick master cylinder?
  13. Dave B
    I don't remember....I had planned on using one of the newer style Ford masters (the plastic ones) I'll see if I still have it out there, and mock it up on my project car, and see....(I'm getting old, I forget some things)
  14. Ryan
    Ryan Ford Addict
    Phoenix Az.
    That would be great Dave, whenever you get the chance, i hear it is a far walk and you must resist the cold coronas on way. :beerchug:
  15. car-nut
    car-nut Glenn
    conn.
    Subscribed! This is something I have been thinking about doing soon. I need to figure out the master and booster before I get ready to paint the engine compartment.
    Looking forwars to whatever you can show us Dave.
