mferguson - new member - Indianapolis, IN
Discussion in 'New Members Forum' started by mferguson, Mar 10, 2011.
  1. mferguson
    mferguson New Member
    indianapolis, IN
    1972 4 door maverick
    Have a '72 Maverick 4 door. Looking for a fuel tank. Aftermarket tanks are 19 gallon for later years. Anyone know where I can get replacement stock 15 gallon tank?
  2. Shorty
    Shorty Member
    Lafayette, In
    Welcome from a fellow Hoosier and good luck on the tank search. Someone here will probably have one.
    Bruce
  3. rthomas771
    Use the later tank. Be sure to buy the newer vapor valve to fit the tank. You will need new 1/2" longer strap bolts. While your at it get a unleaded filler tube with the trapdoor to speed up pumping gas at the gas station and this will also stop most of the splash-back...welcome to the board.
  4. don graham
    Welcome to the board.:Welcome:
  5. Terry1
    Terry1 Member
    Warner Robins, GA
    1974 Comet GT
    What is an unleaded filler tube and where do you get one. I know what a filler tube is, but an unleaded tube? I hate the splash back.
  6. rthomas771
    The unleaded filler tube has a small trap door inside the tube. This trap door made it impossible to insert a leaded gas nozzle in the tank. Leaded nozzles were bigger in diameter than the unleaded nozzle
  7. mavgrab302
    Welcome from Ocala,Florida..........
  8. Craig Selvey
    I am up near Muncie, IN and have some tanks. Email me directly (see below) if I can help.
  9. mav1970
    :Welcome:from Northeast Pennsylvania
  10. Mercurycruizers
    Venetia, PA
    :Welcome:to the board.....
  11. bri
    bri midnight special
    mission city b.c. canada
    71 comet GT. 414 cu, c-4, 9+, spool 3.25, 35 spline axles, back halved,12 point,,4 whl wilwood discs, 3 link,tubbed. 73 comet sdn 302, 76 comet 2dr 6 cyl, 84 z-28 468. 98 f-150 4x4 5.4, 98 fld 120, 500 detroit. 09 jeep grand cherokee.
    welcome :)
  12. 72nuggett
    72nuggett Member
    varnell ga.
    72 maverick
    :Welcome:TO THE BOARD
  13. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    :Welcome:to the site!!!!!
