that be the front cross member... i was sanding the bottom frame snouts and got to the cross member and when i hit it with the wire brush it was galvanized. the paint came right off. i am looking for a primer that you (i) can put on galvanized metal... the ...rust-oleum primer...i am useing said not to use on galvanize.. i had a painter tell me today to use vingar. he said wash the metal with it and let it dry and then prime and paint. anyone have any info. on the subject??? thanks :Handshake ...frank...
wipe the galvanized down with vinegar, it'll neutralize the coating so you can prime and paint over it
I agree on the vinegar and water, it alsoworks fantastic when spraying your garage door when etching the aluminum
So, you're insinuating that you lost your genitals in an unfortunate smelting accident? Groovy baby...
