MIT helps Ford apply pressure
Discussion in 'Ford Industry News' started by Mav.bot, Aug 11, 2007.
  1. Mav.bot
    Mav.bot Member
    Filed under: Green, Tech, Ford
    [​IMG]Ford is looking for ways to pack their automobiles with innovative technology that achieves the seemingly impossible goal of using smaller, more efficient engines while still delivering the performance wallop customers are demanding. Not only is the Blue Oval seeking more involvement from their suppliers to push new technology and techniques forward, but the automaker's also looking outside the typical realm of automotive OEMs.
    One promising new technology is a system developed by a Massachusetts Institute of Technology startup company. Putting a modern-day spin on the concept of water or alcohol injection to either boost octane or cool the cylinder charge (or both), the MIT developed fuel injection system uses direct injection to deliver a shot of ethanol when the engine is under heavy load. The intravenous drip allows turbocharger boost pressure to be cranked way up, adding a significant amount of power gain. Normally, with your wastegate actuators cranked all the way down, you'd discover new and exciting ways to ventilate the crankcase, but this system keeps detonation at bay, which keeps the pistons in the block.
    [Source: Automotive News - Sub. Req.]
    Continue reading MIT helps Ford apply pressure
    Read | Permalink | Email this | Comments
    More...
