Modern wiper arms?
Discussion in 'Technical' started by AppMaverick, Dec 16, 2013.
  1. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    I wanna put modern windshield wipers on. I have multiple original arms where the spring doesn't hold the wiper against the windshield. Trying to find more modern arms. I'd also like my choice of blades at the parts store...
    Is this possible without a major project?
  2. injectedmav
    injectedmav Member
    Georgia
    I'm using wiper arms from an 89 Escort. Standard pin type mount, lots of blade choices but I like the current Motorcraft ones. When they stop cleaning, wipe the blade with an alcohol wipe and good as new.
  3. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    Sweet! Thanks! I bet they have those at advanced auto.
    Keep'm coming! Couldn't find much about this at all on the forum...
  4. injectedmav
    injectedmav Member
    Georgia
    you might need a salvage yard. At the time, I had one in my back yard:rolleyes:
  5. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    oh :(
    That makes me sad.
  6. MSmithPDX
    MSmithPDX Member
    Portland, OR
    I've always just put them on. Most of the good brands come with an adapter to slip on the end. I'm running these fancy things and all I did was pop them on.
  7. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    That's interesting. Might have to try carquest... Advanced auto ended up only having one type of arm, and they said there's no way it would work.
    Do you know where you got the "pop them on" guys?
  8. MSmithPDX
    MSmithPDX Member
    Portland, OR
    I just buy whatever wiper I want and use it. Seriously I think you guys are over thinking this. You just strip off the original plastic bit at the end, get to a bare metal arm; and slide on the new attacher piece. Put on a little adhesive if you want (I never have, and done this to 2 Comets).
  9. rthomas771
    There's no plastic anywhere on original wipers that I know of. It's all metal and rubber
  10. groberts101
    groberts101 Member
    Minneapolis, MN
    That.. and like tires.. not all wiper arms are created equal despite similar appearance.
    Personally.. I always use the high end Bosch stuff. Always works well and lasts longer to help offset the higher price. And nothing to glue either. lol
  11. MSmithPDX
    MSmithPDX Member
    Portland, OR
    Yea that is true I was just thinking make sure theres nothing on the end that shouldn't be there. Maybe someone already put some adapters on and he just doesn't know it. Just wasn't thinking about it that deeply.
  12. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    The only arms they had in advanced auto had a hole going through the spot where it mounts to the car. Looked like it got a screw through it or something. It was plastic :hmmm:
  13. MSmithPDX
    MSmithPDX Member
    Portland, OR
    The Rain-X ones come with an adapter that works amazingly.
    You just have to get the one for "bayonet arms".
  14. cyclonewill
    cyclonewill Member
    SandSprings, Oklahoma
    I have modified Ranger wiper arms on all of my old cars. I like the attachment better, besides none of my cars are show quality anyway.
    I drill out the rivet, pull the arm apart, cut to length, drill, bend and reassemble. Its pretty straight forward, and gains the ability to hold the wipers off the windshield while you wash it.
  15. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    Looks like I won't be able to get anything that works locally... Anyone have a part number on a modern style compatible arm? I'll order them online.
