modulator valve question
Discussion in 'Technical' started by agent281, Sep 1, 2010.
  1. agent281
    agent281 Member
    murray ky
    1974 maverick inline 6
    Oook, well I replaced my modulator valve and I noticed that I can turn it back and forth ....is there somewhere specific it is supposed to be set or does it not matter? Thanks!
  2. PaulS
    Your 74 C4 is held in place with a clamping spring that is bolted to the extension housing. The modulator is sealed with an o-ring. It is free to rotate and it really isn't likely to hurt anything - the hose will keep it from spinning if it is a tight fit.
