more odd sounds from the maverick???
Discussion in 'Technical' started by Matterick, Sep 9, 2008.
  1. Matterick
    Matterick Matt Somerville
    Lake Stevens WA
    this is gonna be hard to explain but when you are in drive and you give some gass something rattles and clicks over and over again... its pretty loud and its embarrising and it only does it when you step on the gas and it doesn't do it in park or neutral... sound familiar to anybody???
  2. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    Sounds like pinging to me.
  3. yellow75
    Tillamook Oregon
    Could be a u joint, crawl under the car and see if your driveline moves around much with the car in park.
  4. hacksaw415
    hacksaw415 Member
    slum bum frisco
    75 booger green mav
    i tracked down a funy clicking, it was my wheel bearings. then there was that odd clunk when you go on or off the gas, that was the trans mount, and then thre was that banging whenever id hit a bump,that was the missing sway bar bushing that let the bar hit the frame. ive heard these are common maverick noises.
  5. yellow75
    Tillamook Oregon
    How true it is, you fix something then you find something else its a viscous circle but you know you love it, at least on these cars you can fix it, and not depend on a shop to plug it into a computer to tell them whats wrong and start chaging parts until they get the right one.
  6. baddad457
    :D I'll bet it's his muffler bearings going bad.;)
  7. 71gold
    i don't think they had... muffler bearings ...in '73...my '73 didn't, so i was thinking they discontued them in '72...Dan or Craig might know...
    i would guess...u-joint...
    ...:Handshake...
  8. Matterick
    Lake Stevens WA
    alright thanks guys for the advice i'll check out all these things later cause i gotta get out to the bus stop lol :burnout::chirp:
  9. Bob Wiken
    Fayetteville, Arkansas
    I'd check for a loose or worn Flux Capacitor mount bushing. Usually it's the rear right side that goes and they are a bear to replace. GL.
  10. Dave B
    Check you emergency brake cable connector, it could be rattling on the exhaust.
  11. Centerline
    Centerline Member
    Washington State
    1971 Ford Maverick Grabber
    Does it sound like a sewing machine? #1 - check all your fluids. #2 - take your valve covers off and check to see if a rocker fell off a lifter, although I suppose that wouldn't be too loud. #1 will be easier.
    You could check to see if your engine has anything less than 300 ci capacity. If not, it will need to be replaced. Also, Bob's right - the FC unit tends to throw a bushing from time to time.
  12. Matterick
    Lake Stevens WA
    thanks guys for the idea's... :thumbs2: i'm gonna get it up on a rack tommorow and i'll check all these things.
  13. Matterick
    Lake Stevens WA
    well i'm gonnna check it out today and get that glasspack back on instead of the muffler
