Almost the whole car is stripped of all paint now.Ended up using aircraft stripper,and 3m paint stripping discs.You can see the huge gob of bondo some idiot used to fix a dent in the quarter panel,thats all getting removed and fixed a lil better.Decided to fill in the marker lights too for that lil extra bit of being different.Its progress,slowly but surely.Luckily the only metal that needed to be replaced was a tiny bit behind each rear wheel,and a lil bit under the battery,other than that the car is SOLID!
