More stopping power
Discussion in 'Technical' started by 1moregear, Jun 7, 2009.
  1. 1moregear
    1moregear Member
    mississippi
    74 and 76 maverick
    If you already have disc brakes and wanted to upgrade your calipers and rotors ( bigger) and use the same spindles are there any parts that interchange? Are front brake lines Maverick specific or will mustang say 1970 -73 work since you can get braided lines for them. Thanks for any imput.
  2. ultrastang
    ultrastang Member
    Arkansas
    As a matter of fact, yes. This setup is shown on a '75-'80 Granada spindle [for adaptation to a '65-'73 Mustang], but this spindle design was actually first available on the Mavericks/Comets starting in '74 before they carried over into the '75-'80 Ford Granada/Mercury Monarchs.
    The 13" rotor and alumium twin piston PBR caliper is from the '94-'04 SN95 Cobra Mustangs.
    If you would like more information, you can contact me at:
    steve@ultrastang.com
  3. maverick5.0
    maverick5.0 Member
    Caribbean/Puerto rico
    1976 maverick,347 stroker,c-4,sm bumpers,frt air dam/73 maverick,5.0 grabbber hood,four on the floor,v8,rear spoiler,...
    ultrastang, what size wheels will clear the calipers???? do you have a direct link for more info ???? -mel-
  4. TrikeKid
    TrikeKid Member
    Roy/Eatonville, WA
    '85 Toyota Pickup, 74 V8 Mav
    I would bet you'd need at least 17's, that's what the Cobra ran all the way through.
  5. maverick5.0
    maverick5.0 Member
  6. krelboyne
    krelboyne Remember
    Salem, Oregon
    The Ford part number for disc brake hoses is D6AZ-2078-A, right and lefts.
    Your factory disc brakes should be more than adequate, if they are in perfect working order. You running a booster?
    Upgrading the rear drum brakes is what I would look into.
    Stock are 10 x 1-3/4" shoes.
    The small 6 cylinder rear drums are 9 x 1-1/2".
    They can be upgraded to 10 x 2" or 10 x 2-1/4". Should be a bolt in to your existing 8 inch rear end.
    Drums, backing plates, wheel cylinders, and hardware from a 1968-71 Ford mid size. I believe that 1972 or 73 was the year that Ford changed to the large bearing axles on mid sized and larger.
    Heavier duty brakes are easily found on station wagons and Ranchero's.
    10 x 2" backing plates are the easiest to find on on cars such as, 1969-71 Cougars.
    The Maverick/Comets use the small 2-13/16" rear wheel bearings, so the earlier backing plates and drums are required.
    10 x 2 drums are available repop fairly reasonably.
