Motor mounts not lining up
Discussion in 'Technical' started by SBMVRK, Jan 22, 2015.
  1. SBMVRK
    SBMVRK Member
    San Jose, California
    1974 Ford Maverick
    Hello everybody, I just dropped in a 5.0 into my maverick with new mounts and brackets bolted on. I am currently at a stand still as the passenger side mount doesn't want to seem to align properly.I got the drivers side bolt in fine but now it seems lIke the whole engine needs to move about an inch to the passenger side. I've tried prying at it, jacking it up in various places and it will only move it up and down because of the bolt on the other side. Any tips or tricks would be great! Thanks guys
  2. Mel Moeller
    Mel Moeller Maverick Moe
    Twin Falls Idaho
    1971 Ford Maverick, Two 1973 Mavericks, 1974 Mercury Comet
    There is a left and a right frame mount. Do you have them in correctly?
  3. SBMVRK
    SBMVRK Member
    1974 Ford Maverick
    I believe so. The driver side is considered the left mount correct? Because I'm pretty sure that's what side I put it on
  4. Mel Moeller
    Twin Falls Idaho
    Always make sure your tabs on the frame mounts are pointing down not up.
  5. biggruss
    biggruss Member
    picayune,ms.
    1970 maverick grabber,1975 maverick (parts car)
    are the tabs on the frame mount pointing down
  6. SBMVRK
    SBMVRK Member
    1974 Ford Maverick
    What do you guys mean by tabs? Can you tell that mine are wrong In the pictures?
  7. Craig Selvey
    Not all frame mounts have the tabs.
  8. biggruss
    biggruss Member
    picayune,ms.
    20150108_033625.jpg mine look like this
  9. SBMVRK
    SBMVRK Member
    1974 Ford Maverick
    Yea mine are aftermarket and don't have those tabs on the brackets. I'm almost to the point of drilling another hole in the bracket.
  10. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Hard to tell in your pics(cant tell if we're looking at the front or back), but it looks have them on the wrong sides, offset goes toward the fire wall.
  11. mercgt73
    mercgt73 Member
  12. SBMVRK
    SBMVRK Member
    1974 Ford Maverick
    Thanks guys my mounts and brackets seemed to be on right. I finally was able to get both bolts in after hours of screwing with it. Now I gotta wire everything up for efi.. I'll probably be back haha
  13. joee
    joee Member
    70 maverick
    I leave the bolts to the block in with only a couple of threads until I get the thru bolts thru
