motor mounts
Discussion in 'Technical' started by Sursmilie71, Jun 6, 2025.
  1. Sursmilie71
    Sursmilie71 Member
    Great Falls SC
    71 Graber
    Are the Maverick motor mounts different from all others? I can't find them. what is the part #? Where is a good place to get parts?
  2. TeeEl
    TeeEl Senior Member
    Colorado
    '73 Ford Maverick Resto-Mod
    Are you talking about the frame stands? Or the mounts that bolt to the engine block?...
  3. Krazy Comet
  4. Craig Selvey
    What motor?
  5. Sursmilie71
    Sursmilie71 Member
    Great Falls SC
    71 Graber
    302 motor mounts only. What is the difference from slandered mounts?
  6. Sursmilie71
    Sursmilie71 Member
    Great Falls SC
    71 Graber
    thanks Krazy
  7. dyent
    dyent Member
    vancouver bc
    The original 302 motor mounts had a "stud" that attached to the upper/lower halves (which prevented mounts from separating) and was filled in with rubber. All the aftermarket ones that I have seen, only have rubber that bonds the halves together......
    You can see the "stud" version in the 2nd picture of the RockAuto link that Tom provided......
    David
  8. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
  9. TeeEl
    TeeEl Senior Member
    Colorado
    I would suggest getting the mounts with safety anchors (like the factory used) if possible.
    Many of the cheaper replacement mounts don't have them.
    If they are not available, you can make your own safety anchors...
    rthomas771 likes this.
