motor swap
Discussion in 'New Members Forum' started by lincmave, Feb 24, 2013.
  1. lincmave
    lincmave New Member
    newbrighton pa
    77 maverick,89 linc mark 2000 f350 superduty
    great to be here:comet:i was wondering if any one has swaped a5.0 efi out of an 89 linc mark into a 1977 ford mave with a200 i6 i also am planing on using aod trans, if so what am i in for
  2. Moneymaker 1
    Panama City Florida
    Alot of work...Welcome from Panama City, Florida.... ya gotta have the parts to do the swap, V8 mounts and frame stands, belly bar (crossmember) and some other parts, Frank (71gold) I believe makes and sells a tranny mount that will work for the AOD swap, if you are planning on keeping the EFI there are some others on here that can direct you.
  3. mav1970
    :Welcome: from a fellow Pennsylvanian just south of Wilkes-Barre
  4. Paul Masson
    1971 Grabber
    :Welcome: from Atlantic Canada.
    The "Search" function will be your friend! Lots of reading material here to give you direction on what to look for, where to go, and yes even pick up some parts.
    Good Luck!:thumbs2:
  5. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    :Welcome:to the site!!!!!
  6. schroensr
    schroensr knight Runner
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    Welcome to the forum from West Virginia.:Welcome:
  7. 71gold
    :Welcome:...:Handshake
  8. Krazy Comet
    A LSC EFI harness is a major bitch to work with as it also has the air suspension and ABS integrated in it...
    BTW the LSC AOD is longer than the std passenger car versions that are same as a C4, also I doubt the wimpy rear used with the 200 will live behind a 5.0... The LSC 8.8 could be modified to work, but axles are probably 3" longer on each side...
  9. Red1972Grabber
    Northern California
    Welcome from Northern California!:chirp:
  10. Mercurycruizers
    Venetia, PA
    :Welcome:to the board....
  11. rthomas771
    The 77 Maverick rear end will hold up well to the Lincoln’s 5.0. The 6 cylinder and V8 got the same rear end after '73
