mounting a grabber spoiler?
Discussion in 'Technical' started by 71maverickGT, May 5, 2013.
  1. 71maverickGT
    71maverickGT Member
    NY
    71 maverick gt
    curious if some of you have mounted a grabber spoiler before? if anybody has measurements from center to center of each hole would be great. or maybe a template? trying to do a neat job any help would be great thanks guys.
  2. don graham
    You might want to get hold of Craig Selvey. I believe he used to loan out a template. Just pay for the shipping. Good luck.
  3. Mavaholic
    It is pretty easy to do without a template. Just lay the spoiler across the deck lid and use the studs to mark the center of each hole. Center punch the marks and drill with a metal 1" hole saw. If you look at the profile of the trunk, you drill right in the center of the radius.
  4. 71maverickGT
    71maverickGT Member
    NY
    71 maverick gt
    thanks guys, i honestly would like to use a template ill try to get a hold of the guy with it. its probably not hard to do but im a perfectionist. worse comes to worse ill just use the 1 inch hole saw.
  5. mav1970
    That is exactly what I did and it came out really well. I was off just a slight hair with a hole or 2 and few seconds with a round file fixed me right up (y)
  6. Ronald Hopkins
    Ronald Hopkins Member
    Morristown Tennessee
    1972 Comet GT
    I did like Mavaholic did when I installed a Grabber spoiler on my Comet.
  7. Craig Selvey
    I have the template. Just email me DIRECTLY (see below)
  8. 71gold
    sitting the spoiler up on the lid is what I did, that's exactly where the holes go...:huh:
  9. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    You don't need a template. Just measure the positions of the studs and mark them on the trunk lid. Use a hole-saw, and drill right on the edge at a 45 degree angle. Easy stuff.
