moving the key TO the dash?
Discussion in 'Technical' started by xpsnake, Dec 2, 2004.
  1. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    I would really like to have a dash ignition. Do they sell a cylinder with the right hardware to do something like this? I imagine it would need some kind of bracing to fit right. Doing the metal work on the dash is something my shop can do no problem, so that part is not an issue.
  2. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    I would think you would also want a 69 1/2 steering column to complete the look since any other steering column would have the ignition lock cylinder in it. I would also think you would need the proper wiring harness. I think it was bolted to the package tray to no metal work should be required. Best bet would be to have a 69 1/2 parts car and swap everything out of it .. Good luck ... I wouldn't mind that conversion either but with a 77 model car you don't have a package tray either.
  3. xpsnake
    xpsnake Bruce
    dmhines: Here's my thinking. Get the bezel for the cylinder, then indent the curved portion of the dash for it, figure out the wiring and then make a new fiberglass trim piece for my now-empty column. I'm not concerned with the factory look vs. the custom look.
  4. 71gold
    dan,
    i put a package tray in my "73 and "77...frank...
  5. Earl Branham
    Lugoff, SC
    Guys, I have a '69.5, and I could take pics of any of the things you need. Let me know.
  6. stockhatch
    stockhatch Re Member
    Boiling Spring Lakes NC
    '72 Grabber
    Oh! I want to see pics of the coveted in dash ignition. Could you post some up Earl? I am considering moving my ignition to the dash like xpsnake because the stock one is broken anyways(won't lock even with the key out).
    Thanks,
    AC
  7. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Why could us late model guys not just put an early Ford key switch in our upper dash near the ashtray or on the lower near the radio?
    Mustangs had in dash ignition till 69, so parts shouldn't be hard to get. Their switches were incorporated into the main dash panel (most any other Ford/Linc./Merc as well). It seems it would look more integrated as well if it was in the main dash rather than a pod on a tray. The factory way is not always the best way.
    Dave
  8. Earl Branham
    Lugoff, SC
    stock; I will post some up when I get a chance. Have a few irons in the fire, but it should be soon.
  9. Kilg0re
    Kilg0re Doh!
    Lees Summit, Missouri
    I would like to have mine on the dash also.. I don't really care if it looks stock i just like the look of it being on the dash and not colum
  10. stockhatch
    '72 Grabber
    I wish there was room over by the headlight switch. Having the ignition there would look totally sweet. Im afraid that putting it over by the ashtray may be too far out of the way and look kinda stupid...
    AC
  11. ratio411
    ratio411 Member
    Pensacola
    On 60 something Ford/Linc/Merc products, you were liable to find the key switch anywhere on the dash within arms reach of the driver.
    I have seen cars with them high, low, far left (by our lights), far right as the driver might reach, and any place between.
    It would be more important to me to source a switch and maybe bezel that looks at home where I decide to put it.
    Slightly off topic:
    Has anyone ever fused their ashtray door into the dash?
    Like it was never there... smooth surface to match the rest of the dash...
    That is what I would like to do, gain more smooth dash close to the driver.
    Dave
  12. xpsnake
    xpsnake Bruce
    Hey guys, maybe something like this?
    Also, Dave, that's not off topic, I was considering the same move myself, I will never, EVER use my ashtray, so why not remove it alltogether?
  13. syklops75
    syklops75 Dont touch the spark plug
    suwanee, ga
    1972 4 door maverick
    why not put the ignition switch where the cig lighter is. so you could have a "hidden" ignition when ashtray is closed? i was thinking of putting a manual choke there myself
  14. Mavaholic
    I put my ash tray area to good use.
  15. syklops75
    suwanee, ga
    good point... but seeing hows my car will probably never need all that. (one can dream that it will)...i still like my idea
