MSD 6AL questions???
Discussion in 'Technical' started by JC13, Nov 16, 2002.
  1. JC13
    JC13 Loyal To The Maverick
    Colorado
    1973 Maverick
    I hooked-up my MSD today using the wiring diagram on the back. I unhooked the old modulator and this is how it went...The orange wire to pos coil, small red to pos coil, small black to neg coil, big red to bat side of solinoid, big black to ground, white not used, violet to orange and green to violet on mag pick up. turnd over fine but the car would not fire.
    Question 1. Do I have to use a high performance coil with the MSD?
    I put the old one back in and same thing the car would not start.
    Question 2. Could I have fried the coil with the MSD?
    Question 3. If a coil says "use with primary resistance wire or external resistor" where are these located and how are they hooked up? I don't think I have this.
    Thanks JC
  2. JC13
    Colorado
    1973 Maverick
    white wire hook up
    should I not use the green and violet magnetic triger hook up and use the white wire hook up instead? If I do that is the old modulator used too?
    thanks again
  3. Mavericknutt
    Mavericknutt member
    BoisdArc mo.
    1971 maverick 2dr m2 front end coil over ladder bar rear suspension 472 ci. C-6 tranny
    ok so i'm guessing you are using the ford distributer right?this is how mine is hooked up.small black=negitive coil, orange=positive coil, small red=conected to the redwire on the old coil harness,large red= positive battery,large black=negitive battery,green=green on the distributer,purple=purple on the distributer. this is how mine is hooked up and it works great as far as the stock coil goes.....i'm not sure cause i'm running the blaster 2 coil. but i have been running the stock distributer and it works great.
  4. mavman
    mavman Member
    Arkansas
    The purple wire and the green wire go to the pickup in the distributor. MSD makes an adapater harness to adapt the duraspark plug on the dizzy to the MSD plug on the 6 series box. Sounds like you've got everything hooked up correctly. If your car was originally equipped with a duraspark ignition, you most likely already have a resistance wire. I dont think the orange wire goes to the coil, but the bracket mav is under a cover right now, and I cant check for ya. If I remember right, there is a white wire to the +coil and a black wire the the -coil, tach hooks up to the MSD box on the side. You shouldnt need a resistor at the coil as the MSD supplies 480 volts to it. Just connect the dizzy to the MSD box, power the box, and it should work fine. Good luck!
  5. JC13
    Colorado
    1973 Maverick
    I'm running a 78 distributor duraspark. the harness comming from the distributor has orange purple and black. Thanks for the information.
  6. JC13
    Colorado
    1973 Maverick
    my car is a 73 that used to have a 250 in it now I have an 89 302 in it. I added the duraspark myself.
  7. Mavericknutt
    Mavericknutt member
    BoisdArc mo.
    you only use the white wire if you DO NOT use the mag pickup wires(green& purple) i am actually gatting all of this out of the paper work that came with my MSD (instructions)
  8. JC13
    Colorado
    1973 Maverick
    so if you use the white wire do you use the duraspar modulator too?
  9. Inliner
    Inliner Member
    San Antonio, TX
    '73 4dr Mav (driver), '68 Mustang (racer)
  10. JC13
    Colorado
    1973 Maverick
    I still need help
    I hooked the duraspark back up but have no spark at the coil. I must have done something. My car is 10 miles away and I just spent 2hrs of messing around and it still has no spark. new coil...still no spark. all wires and conections seem good now real resistance in any of the wires. I just don't know. Any trick tests that I don't know of would be a help. Thanks
  11. Mavrick newb
    Mavrick newb 20 Year old Mavrick fan
    Central Point, OR
    1973 Mav 351w 76 Mav 302
    Make sure you insulated the connectors in the distributer (msd connectors they give you are bare metal connectors so they can short out on each other) , if you had to change anything in the distributer...
    I put one on a chevy (i know i just said a bad word leave me alone!) And it wouldnt turn over and I couldnt figure it out and then BAM I went " I wonder if its those 2 connecters in the distributer laying on each other shorting out...." I put black electrical tape on em and ta-da it fired right up. Hope this helps!
  12. CACollo
    CACollo Member
    Abq. NM
    1969.5 Maverick
    There aren't a whole lot of things that can go out to cause no spark. The first would be to make sure that you have your MSD hooked up correctly. Personally, i would dump the duraspark and just run the MSD, especially if you're stuck on the side of the road and just want to get home. Some of the other guys have been giving you advice on which wire to where...make sure you have the white off to the side and taped, if it is touching anything then your car will NOT start!
    The next thing would be the coil...you said you put a new coil on, so that is not the problem....
    The next thing to check would be the pick-up coil, inside the distributor. Honestly, i have never seen one go bad on a ford, but it is possible i'm sure. Depending what year of distributor you're using, there is most likely a stator inside your distributor (eight-sided star type thingie), which passes by the pickup coil. There should not be a very large gap between the two.
    The last thing would be the wire between the coil and the distributor. Although, you'd probably just end up with a weak spark if it was anything but completely severed.
    Oh, also i would check the wire that runs from your MSD box to your ignition switch. Yeah! I bet that's what the problem is....make sure it's got a good connection.
    Anyways, good luck!
  13. JC13
    Colorado
    1973 Maverick
    Hey thanks alot. It was a poor conection on the black wire to the dis.... aground wire I think.
    I also apreciate the advice that I should run the MSD as stand alone. That was my next question. On Saturday I drove to work where I decided to hook up the MSD as a stand alone but it didn't work and now the msd is sitting right here on the floor. I was getting ready to wire it in with the duraspark untill now.
    Thanks Ya'll
