Msd box location???
Discussion in 'Technical' started by 73'goose, Mar 30, 2008.
  1. 73'goose
    73'goose 1/4 mile junkie
    Bay Area, CA
    1973 Maverick
    Curious to see what suggestion everyone has on where to mount the msd box??? i got a 73 maverick
  2. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    I have one....but it is in the box on the shelf b/c I couldn't find a place to mount it that I was happy with. I don't want it to be seen.
    I have heard of people mounting them under the dash up high?????
    Seth
  3. MaverickRunner
    MaverickRunner Member
    North Port Florida
    73 Maverick 302
    Mine is where the battery tray once was, easy to replace the RPM chips.
  4. don graham
    mine is on the drivers side, on the front fender inside the engine compartment. MSD says to keep them away from heat. But since mine is only running for short periods of time, I figure it dosen't hurt. Can't keep it away from heat in AZ. anyway.:)
  5. don graham
    If you go to my gallery pics. there is a photo of the engine and you can see the MSD box in the upper right corner.:)
  6. courier11sec
    courier11sec Member
    Tucson, AZ
    Mines there too. easy access to the limiter chips through the huge hole where the battery once sat!(y)
  7. rayzorsharp
    Where my windshield washer reservoir should be. Don't want that ugly thing on this car. Here's a recent pic I took before the radiator change. :)
  8. mav76302
    mav76302 Member
    Mesquite, Tx
    1976 Maverick Stallion
    that's where i put mine.windshield washer didnt work anyway.
  9. tim keck
    sharps chapel,Tn
    Mine's directly behind the motor,just underneath the gutter where the shock tower braces bolt up.The gutter keeps it dry,mine is just a 6A,so it doesn't have the removable chips.
  10. 73'goose
    Bay Area, CA
    1973 Maverick
    thanks for the input i think i am going to put it in the same location of the pictures don and rayzor has
  11. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Same here, I figure air flow is good with the vents in the core support there.
  12. 73'goose
    Bay Area, CA
    1973 Maverick
    that would be a good idea, but i still have yet to move the battery to the trunk
  13. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    same place for me
