MSD Questions
Discussion in 'New Members Forum' started by pil1sbury, Nov 15, 2009.
  1. pil1sbury
    pil1sbury MavBoy living life
    Virginia
    1974 FORD MAVERICK
    i want to buy a msd ignition box for my 72 maverick sprint but i hear some things that sounded bad about it and i wanted to know is it easy to put in yourself or easer to get another person to do it
  2. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    first of all, nice car!!
    there are a lot of different MSD ignition boxes out there. I don't have any experience owning one but know that a lot of othe cars I see in magazines have them. You may need to figure out what you want out of your can and engine.
  3. Mavman72
    They are easy to install.Follow the directions to the letter and you wont have a problem.
  4. yellow75
    Tillamook Oregon
    x2 just mount it and a little wiring
  5. don graham
    I run one on my 71. If I can do it anyone can.:hmmm:
  6. 71gold
    ...are you running enough compression to need one...:huh:
  7. mav1970
    I just bought a used but tested MSD 6A and didn't get any paperwork with it. Is there a mininum compression needed to run one? My Cleveland is 10 to 1, maybe slightly more. :hmmm:
  8. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    I noticed difference when I installed an MSD 6a on my ~10:1 306, especially in the low RPMs. I can back the idle screw all the way out and it will still run, which was far from the case before. Easy to install and worth it in my opinion.
  9. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I don't think you need a specific compression ratio. You should go on the MSD website and just read up on their ignition boxes, it explains to you exactly how they work. I'm not the right person to explain it to you but maybe someone else can.
  10. Mavman72
    You can also download the install instructions from the MSD site....
  11. 71gold
    on my 9 to 1 motor...
    the dyno didn't show any difference with it on or off. i was told it helps with 10 or better...:yup:
  12. pil1sbury
    Virginia
    1974 FORD MAVERICK
    ya iv been lookin and i want to get one and i just need to get time to put it in. thinks to everyone
