Mustang fuel tank install finished....
Discussion in 'Technical' started by mavgrab302, Feb 6, 2010.
  1. mavgrab302
    I got off my butt and finished my 19 gal. 69 mustang tank... Hear are a few pic's.........
  2. 408w-maverick
    408w-maverick Member
    Oklahoma City
    1974 Maverick 2 door
    looks good,is that the 69's gas cap too?
  3. starsky74
    starsky74 Technician
    Hackberry Louisiana
    what modifications were involved?
  4. mavgrab302
    It's a aftermarket billet aluminum cap, made by Scott Drake $98 bucks...
  5. mavgrab302
    I moved both straps out a couple inches, put a spacer inside the back hanger brace witch you can see in pic #3 and bolted the straps on with one bolt per side... I did this to take up a little slack in the straps.. Lastly I cut a new slot on the brace right behind the valance, I had to beef up that area so the bolt won't pull through..... Oh and I cut 1.25 inches off the filler neck...
  6. car-nut
    car-nut Glenn
    conn.
    So is the tank now centered? Or is it still off set like the stock tank was?
  7. mavgrab302
    Not centered perfect but, I now have 5 inches on pass side and 4 inches on drivers side... The sending unit is in the back now out of the way... :)
    You can see in pic #1 how much room there is between tank and leaf spring........
  8. mojo
    Mavgrab302:
    That install looks real gud + bonus of few more gals of fuel.
    Do u have enough on pass side to get exhaust pipe out that side?
    What abt fuel gage _What's needed to make it work w\ the larger tank?
    I think I wud put some kind of stop on the open side of the rear slots to make sure the tank won't shift -- Otherwise nice job :clap:
  9. mavgrab302
    Yes tons of room now :thumbs2:
