Mustang upper control arms
Discussion in 'Technical' started by GrabberGT, Apr 12, 2008.
  1. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    Can I use 65 Mustang Upper control arms on the Mav? If not is there any amount of modifying them that can easily be done to make them work?
    As always thanks.
  2. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Use 68-73 Mustang front suspension parts for a direct replacement
  3. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    I have a line on a set of Global West tubular off a 65 stang. Can I make them work?
  4. Dave B
    There is a difference between the 66 & the 68 (same as Maverick) I can't find any good pic's to compare them, but they are listed differently in most catalogs.
  5. gdemopesq
    gdemopesq MOTOR CITY MAV
    Michigan
    72 Maverick 302
  6. 71gold
    ...Yes...and good luck...:Handshake
  7. bmcdaniel
    IIRC the earlier Mustang upper arms have a 4-bolt ball joint and the later Mustangs and Mavs use a 3-bolt ball joint.
  8. tweet66
    tweet66 where am I?
    Pennsauken, NJ
    Biggest difference is the upper arm bolt spacing. The bolts that mount to the shock tower are closer on 64 to 66 than later years. The arms can be made to work. If your going to try use the furthest rearward hole and drill a new front hole. This will set the arm further back and give you alot of extra camber (possibly too much).
  9. bmcdaniel
    I think you mean extra caster, unless it also moves the arm outward.
  10. tweet66
    tweet66 where am I?
    Pennsauken, NJ
    Your right, I should read my own drivel before posting. I don't think there will be any outward movement of the arm. The 67 and later Mustang arms are about 1/16" shorter so that'll give a little less camber. I think the issue with using the 64/66 arms occurs because the arm is generally centered on the tower and putting the early Mustang arm in there using the rear most hole could set the arm too far back and the front pivot could possibly contact the front of the tower buldge? I believe the bolt spacing is 3 3/4" on the early arms and 4 1/4" on the later (I'll check that). That 1/2" from placing it the rear hole could put too much caster and make it difficult to even turn the car.
  11. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    Thanks guys. I let them go. I'll keep looking.
