MY 1970 FORD MAVERICK engine
Discussion in 'Technical' started by pacolobo, Jun 29, 2014.
  1. pacolobo
    pacolobo Member
    tijuana mexico
    maverick 70
    hi I have afford maverick 1970 six inline engine 200 ci 3.3 te question I have is do you guys hace some engine spec the thing is I open the engine a take off the head because the head gasket leaks now I don't know how to put back the head whats the order to put it:dance:
  2. Acornridgeman
    Wisconsin
    3 step torque head bolts (use new ones if possible) 55 - 65 - 75 ft lbs
    Coat the threads with a little water resistant sealer (permatex #2 works fine) on the 2 end bolts for the right side. Dip the other bolts threads in a little clean motor oil to lubricate them.
    For the exhaust bolts, torque 13-18 ft lbs
    For the rocker shaft - torque 30-35 ft lbs
    Follow torque sequence in the picture .......... :tiphat:
  3. 71gold
    :Welcome:...:Handshake
  4. pacolobo
    pacolobo Member
    tijuana mexico
    maverick 70
    thank you
    thank you so much acornridgeman you made mi day now is very easy to complete mi project have a nice day acornridgeman . and thank you for the welcomes :thumbs2:
  5. Acornridgeman
    Wisconsin
    You are very welcome ......... :Handshake
  6. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    Make sure you ck the hd before installing to determine whether or not it is warped.If it is & you don`t have it resurfaced,it will blow again.(y)
  7. Mr Nick
    Mr Nick One with many questions
    Grapevine, Texas
    1971 Four-Door Maverick, 1962 Cadillac Sedan deVille (soon)
    Whats the torque sequence on the rocker shaft?
  8. Acornridgeman
    Wisconsin
    The idea is to tighten it down evenly so as not to put too much pressure onto one side or the other and warp or bend the shaft. Set the rocker shaft in place and start each bolt by hand. Snug each one up with just your fingers. Now take a wrench and turn each bolt, one after the other TWO TURNS. Do this until all bolts are firmly seated. Final torque to 30-35 ft lbs.
    :tiphat:
