My 71 grabber
Discussion in 'Drag Racing' started by Boss302maverick, Jun 9, 2011.
  1. Boss302maverick
    Boss302maverick Member
    New Jersey
    1971 maverick grabber
    This is my 71 Grabber, I have owned it since 1980, I run a Boss302, c4, 5.43 gears with a 29X8 tire with cal tracs, car runs 10.60's at 124 mph
    pic of my car car is in the new member section
    Duane
  2. maverick75
    A ten second boss maverick! now that is just plain awesome.
    Fell free to tell us more about the engine :)
  3. Rick
    Rick G8I operations
    Ocala, Florida
    Sweet, what's your trap RPM with them gears.
  4. Boss302maverick
    New Jersey
    runs through the traps at 8500. I shift the car at 8000.
    Duane
  5. ghettoshelf
    ghettoshelf Member
    austin texas
    73 grabber 302 auto
    YEAH!!!!!!!:dance:
  6. bossmav
    bossmav Drag racing nut
    Harrisonburg, Va
    74 Grabber now Pearl white
    That's a lot better then I could ever do with a Boss 302 motor. You must've reworked the heads because factory heads are really the problem with that motor. 5:36 gearing seems a bit steep for 1/4 mile.
  7. Boss302maverick
    New Jersey
    I gotta tell you, Ive had alot of success with the Boss Motor, when I put my first one together, the heads were stock. With 12to1 pistons, a solid cam, the stock dual plane intake, and the hedman hustler headers, the car ran 12.0's , when I put the torqueplates in the heads and put on the roush intake it ran 11.40's, then I filled the intake and heads, did some exhaust port work and put the stinger plates in, a roller cam, tubular automotive headers, and various other things, and the motor makes a touch over 500hp at 8200 rpm on the dyno. The 5.43 gear and a 7inch converter works great for the motor combo.
    Duane
