My brakes are terrible
Discussion in 'General Maverick/Comet' started by gwil81, Apr 29, 2019.
  1. gwil81
    gwil81 Member
    oakland,ca
    1977 maverick
    I swap heads and cam. An seems like car not making enough vacum. What my opinions now?
  2. 71gold
    how big is the cam?
    Crazy Larry likes this.
  3. Krazy Comet
    Either a vacuum pump or maybe a reserve tank.
  4. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    Vacuum reservoir.
    71gold likes this.
  5. gwil81
    gwil81 Member
    oakland,ca
    1977 maverick
    I'm running trick flow heads and cam Street Heat. But I'm running a carbureted
  6. Krazy Comet
    For brakes, size of cam is meaningless. How how much vacuum does it produce at idle? I'll guess 12"?
    Increasing base timing will increase vac but the mechanical/vac curves will need to be reduced so it doesn't have excessive timing at higher RPM.
