My electric fan upgrade
Discussion in 'General Maverick/Comet' started by mashori, Jul 29, 2009.
  1. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Stopped by Bryant's shop, just finished getting my exhaust done and he had a little time so we decided to do the electrical first and do the fitting for the fan later. I showed him all the parts I had and he was able to piece them together pretty easily: I had 2 relays, one fan controlled with the thermo switch in it and of course the taurus fan. Bryant, you got a sweet shop, every tool a man can dream of.
    This is where Bryant suggested it should be mounted:
    He made a bracket that he bent up and pre-drilled:
    And this is the space I have in front of the radiator now, once I go back we'll see what we can get done:
  2. blugene
    That's the space before removing the fan?
    Where's your petcock?!
  3. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I'm not showing you a picture of my percock bro!! :naughty:
  4. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    what's a petcock? :confused:
  5. don graham
    Petcock is a drain for the radiator. :)
  6. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    oh I think it's on the passenger side. I definitely saw it before.
  7. blugene
    This is what it should look like...
  8. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    Mashori, what kind of horn is that? Looks real familiar...
  9. Jamie Miles
    It's off a GM. I have one (two, actually) just like that on my car, that came off an 80's Oldsmobile. Definitely way better then the lame girly sounding factory Maverick horn. Them old GM horns sound like they mean business.
  10. facelessnumber
    Memphis, TN
    '71 Grabber
    That's why it looked familiar. Mine came from a Cadillac. :D
  11. texasjack
    texasjack Member
    Aledo, TEXAS
    1975 Mavrick 4 door
    Horn
    My Mavrick horn sounded like a sick hillary.
    I could not lower my Mav to install an obama motors part on it.
    My friend owns a wrecking yard and I got a set of Towncar horns from him.
    They fit in the same bolt hole the Mav horns were in.
    Now I have a real horn!
    Texasjack
  12. Jamie Miles
    That about sums it up! :biglaugh::rofl2:
  13. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I thought it was a stock horn! shows how much I know. Came with the car.
  14. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Here is the rest of what Bryant and I got done. I got to do a lot of the work this time so I'm kinda proud of myself. But Bryant was ready with a fire extinguisher and his wise wisdom:
    I made the cuts exactly as Jay described in his tech write up for this:
    It's hard to see but this is the bracket that Bryant made and attached the relay and temp control module to it:
    He spliced into the AC wire for the AC switch which activates the fan when the AC is turned on:
    The power came straight from the power wire that goes to the coil. There is basically this set of wires that has 2 red wires and these other 2 wires one of which goes to the oil sensor and the other to the water temp sensor. The other 2 wires I guess go to the coil. That's the one Bryant tapped into.
    The pictures didn't come out very good this time, maybe my lens was dirty but here is some pics of the bolts we used to mount the fan shroud to the radiator.
    Also, on this taurus fan the black wire was ground, the wire with the yellow line was the high speed fan and the other one with the orange stripe was the low speed which we didn't even use.
    We used one of the radiator bolts as the ground wire mount.
    Bryant adjusted the fan to start kicking in when the thermostat opens. Works out great. I drove around in traffic and was sitting with the AC running on a pretty hot day and didn't get over 195.
  15. blugene
    Nice job!
    Well done on writeing it with pics also (y)
