my maverick 200 straight six has knocking or ticking sound
Discussion in 'Technical' started by drumspace, Dec 22, 2013.
  1. drumspace
    drumspace Member
    San Francisco
    recently the engine (6 cyl) has developed a ticking noise, its not evident when you start the engine or when driving for the first ten minutes, it seems to appear after driving in stop go traffic, i can pull up at a stop light and hear the tick, it will at idle go away on its own or if I rev the engine that will kill the noise too. it does return after 2 or 3 minutes. The engine performance id fine, it does burn oil and every 8 months I usually need to change the points and plugs, its due for that now.
    Hoping its not something more serious like a rod/bearing etc...
    I would appreciate any advice from the Maverick community
    Thanks
    Jim
  2. Bryant
    it could be and exhaust leak, bad lifter, or a rod knock.
    you can use a hose against your ear and run the other end around the exhaust manifold and pipes and you will hear an exhaust leak when you close to it.
    if its a lifter, a lot of times a oil treatment will clean out what ever is gumming up the lifters.
    a rod knock will require a rebuild. thicker oil may buy you more time.
  3. rthomas771
    How many miles on the engine and when was the last oil change?
  4. drumspace
    drumspace Member
    San Francisco
    last oil change was about 4 months back when I had a new torque converter installed, I know I need a new muffler which perhaps could be contributing to the sound?
    there are MANY miles on the clock, I think it has been round once
  5. drumspace
    drumspace Member
    San Francisco
    the muffler you think?
  6. drumspace
    drumspace Member
    San Francisco
    or are you trying to be funny? :rofl2::rofl2:
  7. groberts101
    groberts101 Member
    Minneapolis, MN
    to me it seems like a sticky lifter.. or possibly even low oil pressure.
  8. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    I agree, sounds like a sticky lifter or a worn out oil pump.
  9. simple man
    simple man Member
    Bunnell,Florida
    Wouldn't hurt to check and make sure the nuts are tight! I've had loose torque converters make many kinds of sounds. Some from a light ticking to "it's going to throw a rod" sound. :)
