my night at the track
Discussion in 'Drag Racing' started by scrapper60, Mar 29, 2007.
  1. scrapper60
    scrapper60 MCCI Member
    Alabama
    Made 3 runs on the new engine. Blew the tires off of it all 3 runs.
    first pass 1.90 60ft., 8.14 ET, 93.94 Mph
    went downhill from there. I've got to work on the traction.
  2. don graham
    i believe that mph should be in the low to mid 7's. when you get some traction you should drop the et by quite a bit.:)
  3. mavman
    mavman Member
    Arkansas
    I agree...with that MPH you should be well into the 7's. Probably deep into the 7's. Looks very promising!!
  4. scrapper60
    Alabama
    Thanks for the encouragement Gentlemen. It's been a year since I've been to the track with it, so the driver needs to get rid of some cobwebs too.
  5. riporter
    riporter Member
    Charleston S.C.
    Agreed...may be pushin the high 6 second mark hard...whats going on with the traction...what's the setup?
    Imagine it hookin HARD!:burnout: :dance:
  6. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    thats big MPH :agreed:
    Sounds like you have a quick ride in the making :yup:
    You can bring it to Elizabethtown in July...... :dance:
  7. scrapper60
    Alabama
    We have MT ET Streets w/ 20lbs psi on the first pass. 2nd pass 15 lbs psi, went 8:34. 3rd pass 25 lbs psi, went 8:25.
    Also have homemade Cal-Trac type bars. Did some adjusting on passenger side for last run. 3:55 posi diff.
    Everyone said I was smoking the tires to 1/2 track all passes.
  8. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    are you running tubes?
    Also, do you know how much your car weighs?
    that sounds like a lot of air pressure......but I have never ran with ET Streets so I probably do not know what I am talking about.
  9. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    My :2cents:
    Although the mph is very encouraging, I'm not as optimisitic about the e.t. as others. My guess would be 7.5-7.7ish (based on my experience doing 101mph @ 7.2" in a Fox Mustang).
    Also, if you're smoking the tires "halfway down the track" at 15psi, you definetly have a weight transfer issues. What shocks do you have (front and rear)?
    I've had to go as low as 12.5 in a heavier car - but I was leaving on a 150shot of Nitrous in a similar setup!
    Sounds like you've got the makings of a very quick car nonetheless!
  10. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    Very impressive numbers. Good job. I'm having a hard time resisting the urge to go faster.
  11. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    I agree with Rick, et and mph do not go hand in hand, but with the first motor I in PINKY she went 7.70's @ 84-86 mph.....so you definitely have some power with the mph you are running, now the tough part of going fast (quick) getting everything to work together :).
  12. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    NIce numbers you will deffinetly get it going low 7's. Mine generally goes 7.20's with that kind of mph.
  13. Maverick Man
    California
    yep your 60ft says it all... no traction ;) your cars 5 mph faster then mine and i run in the 7.70 - 7.60s all day long.. ok well not all day... but the 4 times they let me go down the track that is ;)
  14. don graham
    i ran the M/T et streets before i changed to the M/T et street drag radials. i always ran about 12 pounds of pressure. what rpm are you leaving at? i left at about 2200 rpm after doing about a 5 second burnout. never had any problem with spinning but if i went higher i had a problem holding it on the line. :) :burnout:
  15. FredH
    FredH Member
    Seminole, FL
    69.5 Maverick
    My car with the 302 was right at 94mph and the ET was consistently in the mid - high 7.30's with a 1.55 60' time.
