My side exhaust, w/pics
Discussion in 'Technical' started by 1971CometGT, Sep 27, 2006.
  1. 1971CometGT
    1971CometGT Member
    McDonough,GA
    I just installed a side exit exhaust system on my Comet. I used Dynomax mufflers that have inlet and outlet on the same side of the muffler(in and out on the FRONT). I have a 120 degree(approx) bend on the exit pipes terminated with a nice set of Dr. Gas tips that transition from 2.5 round to oval. I put this setup together myself because all of the other side-kits out there only had pieces of what I wanted. The Dynomax muff's have a great deep sound and are almost silent at cruise; they are available from Summit racing for $45 each, I think. I also used one of their h-pipe kits; it was around $40. The tips took me forever to find and are NOT in Dr.Gas' catalog or online. You'll have to call them to order. They are not cheap at $170.00 a pair, but I like 'em:bouncy:
    Overall, the system is just what I wanted and it sounds killa'
  2. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    My set up is very similiar ,except I used spin tec mufflers. I love side exit exhaust. Sounds killer. Get a sound clip or video up(y) I had to notch my sub frame connectors to get better fit and ground clearance. Do you have sub frame connectors?
  3. RabidCustoms
    very nice(y)
  4. 1971CometGT
    1971CometGT Member
    McDonough,GA
    I dont have subframe connectors, and probably wont. Dr Gas makes the "frame clearance" tubes, which are just flattened out a bit for about a 3" span of the pipe
    I'll work on a sound clip :)
  5. blugene
    Looks sweet! Give us a shot of the underside(y)
  6. maverick75
    Nice...i'm also going to go with side exhaust for a little while...and i'm also interested in a pic of the underside.Thanks
  7. Sam M.
    Sam M. Just a nobody
    Southern NJ
    I've always liked your car, and it just seems to get better and better!
  8. CornedBeef4.6L
    no longer here
    Man I have checked this post 3 times just to see how good it looks again. I saved the pics this time to my comp.
  9. Dave B
    Looks awesome!!!
  10. signal20
    signal20 Paul VanSteen
    Spring Hill, FL
    Very Nice,
    I want to do the same thing, but with ford mustang side covers.[​IMG]
  11. maverick75
    i was also going to do that but after looking at it it doesnt look right w/o altering the rear valence
  12. 69 ina 1/2
    69 ina 1/2 Fox body nut!!!
    Smog Bernardino, Ca.
    Dude, your car is sweeet!:)
    Is the seam weld on tips on the top side?
  13. Zooomzoomguy
    Zooomzoomguy Member
    Detroit, MI
    73 maverick, 2 door
    could you try to get the underside view somehow? and did you have to bend anything to make it fit?
  14. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    VERY sweet i love the side exhaust look:dance:
  15. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    looks gooooooooooooood!
